주요 콘텐츠로 건너뛰기
Asus Zenfone 3 Max Screen Replacement
필요한 것
  1. Asus Zenfone 3 Max Screen Replacement, SIM card: 1 단계, 이미지 1개 중 1개
    • Locate the SIM card slot on the upper left side of your Asus Zenfone Max 3.
  2. Asus Zenfone 3 Max Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use the iFixit 150mm Flex Extension with the Hex 0.7 bit or the SIM card eject tool.
    • Stick the tool into the hole on the SIM card slot and open the slot with it.
  3. Asus Zenfone 3 Max Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Pull out the old SIM card all the way so it is no longer in the phone.
  4. Asus Zenfone 3 Max Screen Replacement, Back cover: 4 단계, 이미지 2개 중 1개 Asus Zenfone 3 Max Screen Replacement, Back cover: 4 단계, 이미지 2개 중 2개
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  5. Asus Zenfone 3 Max Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  6. Asus Zenfone 3 Max Screen Replacement, Battery: 6 단계, 이미지 3개 중 1개 Asus Zenfone 3 Max Screen Replacement, Battery: 6 단계, 이미지 3개 중 2개 Asus Zenfone 3 Max Screen Replacement, Battery: 6 단계, 이미지 3개 중 3개
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  7. Asus Zenfone 3 Max Screen Replacement: 7 단계, 이미지 3개 중 1개 Asus Zenfone 3 Max Screen Replacement: 7 단계, 이미지 3개 중 2개 Asus Zenfone 3 Max Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
  8. Asus Zenfone 3 Max Screen Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Asus Zenfone 3 Max Screen Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Remove the two 2.5mm Phillips #0 screws located in the upper corners of the device indicated with red circles.
    • After both screws have been removed, detach the white plastic internal panel completely from the device.
  9. Asus Zenfone 3 Max Screen Replacement: 9 단계, 이미지 3개 중 1개 Asus Zenfone 3 Max Screen Replacement: 9 단계, 이미지 3개 중 2개 Asus Zenfone 3 Max Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Next, remove the four 2.5mm Phillips #0 screws surrounding the motherboard component.
    • Following the removal of all four screws, carefully detach the two device cables at the bottom of the motherboard component using the nylon spudger.
    • Next, disconnect the remaining component cable using the same technique described in the previous step.
    • Metal spudgers should not be used on internal components, they are not ESD safe.
  10. Asus Zenfone 3 Max Screen Replacement: 10 단계, 이미지 2개 중 1개 Asus Zenfone 3 Max Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully grip the motherboard and gently lift and remove it from the internal device casing.
  11. Asus Zenfone 3 Max Screen Replacement, Screen: 11 단계, 이미지 1개 중 1개
  12. Asus Zenfone 3 Max Screen Replacement: 12 단계, 이미지 3개 중 1개 Asus Zenfone 3 Max Screen Replacement: 12 단계, 이미지 3개 중 2개 Asus Zenfone 3 Max Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the four 2.5mm Phillips #0 screws at the bottom near the speaker and take the small black plastic cover off.
    • Starting at the bottom, disconnect the antenna (long black wire).
    • Disconnect the tan component.
  13. Asus Zenfone 3 Max Screen Replacement: 13 단계, 이미지 2개 중 1개 Asus Zenfone 3 Max Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Starting from the top of the phone, disconnect the black screen flex cable (the one that is rectangular). Peel it all the way back.
    • Again starting from the top of the phone, disconnect the charging port flex cable (the other black cable) and microphone button. Peel it all the way back.
  14. Asus Zenfone 3 Max Screen Replacement: 14 단계, 이미지 3개 중 1개 Asus Zenfone 3 Max Screen Replacement: 14 단계, 이미지 3개 중 2개 Asus Zenfone 3 Max Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the four 2.5mm Phillips #0 screws that hold the motherboard and remove the motherboard. Follow our motherboard replacement guide.
    • Remove the (blue) daughterboard. The charging port flex cable will come with it.
    • Be careful when removing the daughterboard. It is thin and adhered very solidly to the screen.
    • Move the rubber piece (denoted with orange circles) from the old port to your new LCD assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
chesterclydefelipe
회원 가입일: 03/17/19
139 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 416
