주요 콘텐츠로 건너뛰기
Asus Zenfone 3 Max Battery Replacement
필요한 것
  1. Asus Zenfone 3 Max Battery Replacement, Back cover: 1 단계, 이미지 1/2 Asus Zenfone 3 Max Battery Replacement, Back cover: 1 단계, 이미지 2/2
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  2. Asus Zenfone 3 Max Battery Replacement: 2 단계, 이미지 1/1
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  3. Asus Zenfone 3 Max Battery Replacement, Battery: 3 단계, 이미지 1/3 Asus Zenfone 3 Max Battery Replacement, Battery: 3 단계, 이미지 2/3 Asus Zenfone 3 Max Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  4. Asus Zenfone 3 Max Battery Replacement: 4 단계, 이미지 1/3 Asus Zenfone 3 Max Battery Replacement: 4 단계, 이미지 2/3 Asus Zenfone 3 Max Battery Replacement: 4 단계, 이미지 3/3
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lauren Compton
회원 가입일: 09/04/19
381 평판
안내서 4개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Fall 2019 University of Alabama, Team S1-G3, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 3개
I need to replace asus zenfone 3 max whole body lcd & what ever the requirements i want to know that it can be replaced or it is dead
Hassan Shahzad - 답글
Part not available on amazon & please bring your store to India, as the market is flooded with a ton of counterfeited products.
Deepank Malhotra - 답글
Asus Zenfone max 3, 5.5 এর ব্র্যাক সেল ও চার্জিং লজিক পাওয়া যাবে কি, জানাবেন প্লিজ
mafijur1122 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 47
전체 시간: 3,213
