주요 콘텐츠로 건너뛰기
Atari Lynx Backlight Replacement
필요한 것
  1. Atari Lynx Backlight Replacement, Atari Lynx: 1 단계, 이미지 1개 중 1개
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Backlight Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Backlight Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Backlight Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Backlight Replacement, Backlight: 5 단계, 이미지 1개 중 1개
    • Pull out the logic-board.
    • Pull to the sides the four rubber tabs holding in the screen
  6. Atari Lynx Backlight Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the two 10 mm screws as shown with a Phillips #0 screwdriver in order to remove the shield behind the backlight.
  7. Atari Lynx Backlight Replacement: 7 단계, 이미지 1개 중 1개
    • Flip over the motherboard and remove the shield behind the backlight.
  8. Atari Lynx Backlight Replacement: 8 단계, 이미지 2개 중 1개 Atari Lynx Backlight Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the motherboard back over and desolder the two components that are holding the backlight in place.
    • If you need help with basic desoldering, click here.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
John Lopez
회원 가입일: 01/27/14
446 평판
안내서 4개를 작성함
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 회원
CPSU-MANESS-W14S1G42
5 회원들
안내서 16개를 작성함
1가이드 댓글
Good instructions but my Atari is different
909 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 41
전체 시간: 5,053
