주요 콘텐츠로 건너뛰기
Atari Lynx Battery Wire Replacement
필요한 것
  1. Atari Lynx Battery Wire Replacement, Atari Lynx: 1 단계, 이미지 1개 중 1개
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Battery Wire Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Battery Wire Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Battery Wire Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Battery Wire Replacement, Battery Wires: 5 단계, 이미지 1개 중 1개
    • Desolder both the black and red wire as shown.
    • If you need help with basic desoldering, click here.
  6. Atari Lynx Battery Wire Replacement: 6 단계, 이미지 1개 중 1개
    • Desolder the black wire as shown.
  7. Atari Lynx Battery Wire Replacement: 7 단계, 이미지 2개 중 1개 Atari Lynx Battery Wire Replacement: 7 단계, 이미지 2개 중 2개
    • Desolder the white wire and then the red wire as shown.
  8. Atari Lynx Battery Wire Replacement: 8 단계, 이미지 1개 중 1개
    • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
결론
작성자
5다른 기여자 명과 함께
John Lopez
회원 가입일: 01/27/14
446 평판
안내서 4개를 작성함
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 회원
CPSU-MANESS-W14S1G42
5 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 2,058
