주요 콘텐츠로 건너뛰기
Audio Technica ATH-AD500 Driver Replacement
필요한 것
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: 1 단계, 이미지 1/1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: 2 단계, 이미지 1/1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: 3 단계, 이미지 1/1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: 4 단계, 이미지 1/1
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: 5 단계, 이미지 1/1
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: 6 단계, 이미지 1/2 Audio Technica ATH-AD500 Driver Replacement: 6 단계, 이미지 2/2
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: 7 단계, 이미지 1/2 Audio Technica ATH-AD500 Driver Replacement: 7 단계, 이미지 2/2
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nick Levy
회원 가입일: 01/13/13
177 평판
안내서 1개 작성함
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 회원
CPSU-FORTE-W13S17G19
6 회원들
안내서 17개 작성하였습니다
댓글 2개
where can i buy a replacement driver?
acidxgangster - 답글
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 26
전체 시간: 10,934
