주요 콘텐츠로 건너뛰기
Audio Technica ATH-AD500 Left Headphone Cable Replacement
필요한 것
  1. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Speaker Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 4 단계, 이미지 3개 중 1개 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 4 단계, 이미지 3개 중 2개 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 4 단계, 이미지 3개 중 3개
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference 연결부 납땜 및 납제거 방법.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 5 단계, 이미지 2개 중 1개 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
  6. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 6 단계, 이미지 3개 중 1개 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 6 단계, 이미지 3개 중 2개 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference 연결부 납땜 및 납제거 방법.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Melanie Reis
회원 가입일: 01/11/13
227 평판
안내서 5개를 작성함
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 회원
CPSU-FORTE-W13S17G19
6 회원들
안내서 17개를 작성함
2가이드 댓글
Thank you so much! your guide helped me repair my AD900x!
Anwar X - 답글
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 50
전체 시간: 10,659
