주요 콘텐츠로 건너뛰기
Audio Technica ATH-AD500 Right Headphone Cable Replacement
필요한 것
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: 1 단계, 이미지 1/1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: 2 단계, 이미지 1/1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: 3 단계, 이미지 1/1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: 4 단계, 이미지 1/2 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: 4 단계, 이미지 2/2
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: 5 단계, 이미지 1/2 Audio Technica ATH-AD500 Right Headphone Cable Replacement: 5 단계, 이미지 2/2
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Melanie Reis
회원 가입일: 01/11/13
227 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 회원
CPSU-FORTE-W13S17G19
6 회원들
안내서 17개 작성하였습니다
댓글 3개
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - 답글
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - 답글
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 4,582
