이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Where can i buy a replacement cable? Cant seem to find it anywhere.
Way late, but I would second information about finding a replacement cable.
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - 답글
