이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to replace the [main] LCD screen on the Audiovox CDM-8900.
필요한 것
Remove screw covers (4 in total) using the spudger.
Note: Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
WARNING: The small electronic components inside the phone are fragile; take care not to damage them when completing this step.
Wedge one of the plastic opening tools under the faceplate near the hinge.
Insert the second plastic opening tool under the faceplate and slide it around the perimeter, detaching the faceplate from the phone.
WARNING: Do not detach or tear any wires when completing this step.
Using the spudger, carefully separate the black discs (speaker and microphone) from the inside surface of the phone.
Note: The smaller black disc is glued down, so you may need to use some force to detach it. Both disks will still remain attached via wires.
