주요 콘텐츠로 건너뛰기
Axess SPBT1031 Auxiliary Port Replacement
필요한 것
  1. Axess SPBT1031 Auxiliary Port Replacement, Red Interface Plate: 1 단계, 이미지 1개 중 1개
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
  2. Axess SPBT1031 Auxiliary Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
  3. Axess SPBT1031 Auxiliary Port Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
  4. Axess SPBT1031 Auxiliary Port Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the red interface plate from the black face plate by pulling them apart.
  5. Axess SPBT1031 Auxiliary Port Replacement, Auxiliary Port: 5 단계, 이미지 1개 중 1개
    • Take the red plate and the motherboard and pull apart them apart.
    • Be careful not to damage the motherboard or red plate as you pull them apart.
  6. Axess SPBT1031 Auxiliary Port Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the auxiliary port which is on the left side above the USB drive and to the right of the charging port (auxiliary port has a circular front).
  7. Axess SPBT1031 Auxiliary Port Replacement: 7 단계, 이미지 1개 중 1개
    • To remove the port, heat up 5 different solder points using a soldering iron.
  8. Axess SPBT1031 Auxiliary Port Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Use a desoldering pump to remove the liquefied solder.
    • Then pull off the auxiliary port.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Elvira Lou Evangelista
회원 가입일: 03/09/16
957 평판
안내서 6개를 작성함
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G6
3 회원들
안내서 8개를 작성함
5가이드 댓글
Can you replace with an old phone charging port
Barbara Myers - 답글
Can you replace charger port with a phone charger port
Barbara Myers - 답글
I did not replace the auxiliary port, what I did is replace the on/off button and this guide help me a lot. Thanks!
Diego Rubi - 답글
hey, is there a video or something you can make for just the process of taking off the port. For example, showing which exact points need the solder removed. Thanks.
Michael “Mike” Martinez - 답글
Im not a tech repair guy… I want my speaker to be fixed for me…. Were can i send it to be fixed
jaron curry - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 20,225
