주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Azpen A701 Charger Port Replacement
필요한 것
  1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: 1 단계, 이미지 1개 중 1개
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Charger Port  Replacement: 2 단계, 이미지 2개 중 1개 Azpen A701 Charger Port  Replacement: 2 단계, 이미지 2개 중 2개
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Charger Port  Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Charger Port  Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Charger Port  Replacement, Charger Port: 5 단계, 이미지 1개 중 1개
    • The charger port is located on the underside of the motherboard (as pictured).
  6. Azpen A701 Charger Port  Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the charger port by using tweezers and gently pulling.
  7. Azpen A701 Charger Port  Replacement: 7 단계, 이미지 1개 중 1개
    • Solder and place new charger port.
결론
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
작성자
5다른 기여자 명과 함께
Michael
회원 가입일: 03/11/15
568 평판
안내서 4개를 작성함
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 회원
UCCS-PANKO-S15S2G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 723
