주요 콘텐츠로 건너뛰기
Azpen A740 Speaker Replacement
필요한 것
  1. Azpen A740 Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Speaker Replacement, Speaker: 2 단계, 이미지 1/2 Azpen A740 Speaker Replacement, Speaker: 2 단계, 이미지 2/2
    • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
  3. Azpen A740 Speaker Replacement: 3 단계, 이미지 1/2 Azpen A740 Speaker Replacement: 3 단계, 이미지 2/2
    • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: How To Solder and Desolder Connections
    • After switching out the old speaker, just follow the directions in reverse to finish.
결론
Mallory
회원 가입일: 01/21/15
346 평판
안내서 3개 작성하였습니다
USF Tampa, Team 4-5, Brown Winter 2015 USF Tampa, Team 4-5, Brown Winter 2015 회원
USFT-BROWN-W15S4G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 115
