주요 콘텐츠로 건너뛰기
Basis B1 Band LED Screen Replacement
필요한 것
  1. Basis B1 Band LED Screen Replacement, Watch Strap: 1 단계, 이미지 1/1
    • Wedge a plastic opening tool between band contacts.
  2. Basis B1 Band LED Screen Replacement: 2 단계, 이미지 1/1
    • Push in plastic opening tool until the components click and pop out of the holder.
    • Repeat steps for other band.
  3. Basis B1 Band LED Screen Replacement, Back Plate: 3 단계, 이미지 1/1
    • Remove four 4mm screws using a PH000 screwdriver.
    • Remove back plate.
  4. Basis B1 Band LED Screen Replacement, Battery: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove elastomeric, or zebra, connector.
  5. Basis B1 Band LED Screen Replacement: 5 단계, 이미지 1/2 Basis B1 Band LED Screen Replacement: 5 단계, 이미지 2/2
    • Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
  6. Basis B1 Band LED Screen Replacement: 6 단계, 이미지 1/1
    • Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
  7. Basis B1 Band LED Screen Replacement, LED Screen: 7 단계, 이미지 1/2 Basis B1 Band LED Screen Replacement, LED Screen: 7 단계, 이미지 2/2
    • Use PH000 screw driver to remove two 6mm bracketed screws.
    • Remove bracket.
  8. Basis B1 Band LED Screen Replacement: 8 단계, 이미지 1/1
    • Use PH000 tool to remove two 4mm screws.
  9. Basis B1 Band LED Screen Replacement: 9 단계, 이미지 1/1
  10. Basis B1 Band LED Screen Replacement: 10 단계, 이미지 1/1
    • Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
  11. Basis B1 Band LED Screen Replacement: 11 단계, 이미지 1/1
    • Use spudger tool to remove the LED screen from the watch case.
결론
Kaitlyn Lee
회원 가입일: 11/06/17
518 평판
안내서 4개 작성하였습니다
IUPUI, Team S6-G1, Baechle Fall 2017 IUPUI, Team S6-G1, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S6G1
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 209
