주요 콘텐츠로 건너뛰기
Nextbook Premium 7SE Battery Replacement
필요한 것
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Nextbook Premium 7SE Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Nextbook Premium 7SE Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: 2 단계, 이미지 1/1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: 4 단계, 이미지 1/3 Nextbook Premium 7SE Battery Replacement: 4 단계, 이미지 2/3 Nextbook Premium 7SE Battery Replacement: 4 단계, 이미지 3/3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: 5 단계, 이미지 1/3 Nextbook Premium 7SE Battery Replacement: 5 단계, 이미지 2/3 Nextbook Premium 7SE Battery Replacement: 5 단계, 이미지 3/3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
    • Use caution when operating the soldering iron.
결론
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
다른 한 분이 해당 안내서를 완성하였습니다.
Walker Karstens
회원 가입일: 10/30/16
364 평판
안내서 3개 작성하였습니다
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 706
