주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Solo 3 Battery Replacement
필요한 것
  1. Beats Solo 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Beats Solo 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: 3 단계, 이미지 2개 중 1개 Beats Solo 3 Battery Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: 4 단계, 이미지 2개 중 1개 Beats Solo 3 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
McKenzie Hosey
회원 가입일: 03/21/22
327 평판
안내서 1개를 작성함
8가이드 댓글
Where too buy battery?
GSD - 답글 공유
Google . Internet
Mari Carmen Núñez - 공유
Thank you! This worked great!
NYCGinkgo - 답글 공유
Hello I have an issue where the battery is soldered on and only has two wires can anyone advise. My headphones are beats solo3
agustin rodiles - 답글 공유
same issue too
ethan b - 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 97
지난 30일: 431
전체 시간: 23,924
