주요 콘텐츠로 건너뛰기
Beats Solo 3 Motherboard Replacement
필요한 것
  1. Beats Solo 3 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use an opening tool to open the headband at the color seam.
    • The audio board is located inside the "Left" ear cup.
  2. Beats Solo 3 Motherboard Replacement: 2 단계, 이미지 1/2 Beats Solo 3 Motherboard Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to carefully remove the yellow polyimide tape that is attached to the morherboard.
  3. Beats Solo 3 Motherboard Replacement: 3 단계, 이미지 1/1
    • There will be three bundled cables attached to the motherboard. Carefully pull them out of each prong.
    • Make sure to take note of which one belongs where for reassembly later.
  4. Beats Solo 3 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four screws that hold the motherboard in place.
    • The cap on the outside of the headphones will fall off once the final screw is removed. Do not fear that something broke. Simply reattach during reassembly phase
  5. Beats Solo 3 Motherboard Replacement: 5 단계, 이미지 1/1
    • Finally, remove and replace the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jakub Karl
회원 가입일: 03/21/22
186 평판
안내서 1개 작성함
University of Alabama, Team 1-2, Bedsole Spring 2022 University of Alabama, Team 1-2, Bedsole Spring 2022 회원
UA-BEDSOLE-S22S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
no suena el altavoz izquierdo do los cascos en modo inalambrico
supongo que es placa base
?puede decirme donde puedo comprar placa base?
l1967e - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 63
30일 전: 318
전체 시간: 6,980
