소개
This is a motherboard replacement guide for the Beats Solo3 Headphones. The model number is A1796. This guide will show you how to safely and accurately remove and replace the motherboard from your headphones. The motherboard allows audio to be played wirelessly through any device such as a mobile phone. Symptoms that can result in a motherboard replacement can be found on our troubleshooting page.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
hey, I'm working on my headphones rn because of a connectivity issue. I believe I found the problem: one of the bottom bundled cables is cracked on the plastic casing that connects the wires to the motherboard, and it's the bottom one (the one unplugged in your picture). Do you know that that wire/cord does? is it related to the Bluetooth or connectivity of the headphones?
I also just saw your profile picture and I'm from Alabama, roll tide
