주요 콘텐츠로 건너뛰기
Beats Studio 2 Wireless Battery Replacement
필요한 것
  1. Beats Studio 2 Wireless Battery Replacement, Battery: 1 단계, 이미지 1/2 Beats Studio 2 Wireless Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: 2 단계, 이미지 1/2 Beats Studio 2 Wireless Battery Replacement: 2 단계, 이미지 2/2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: 3 단계, 이미지 1/1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: 4 단계, 이미지 1/1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: 5 단계, 이미지 1/3 Beats Studio 2 Wireless Battery Replacement: 5 단계, 이미지 2/3 Beats Studio 2 Wireless Battery Replacement: 5 단계, 이미지 3/3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jack Wilson
회원 가입일: 03/20/23
494 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 28
30일 전: 146
전체 시간: 2,396
