주요 콘텐츠로 건너뛰기
Beats Studio3 Wireless Speaker Replacement
필요한 것
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: 1 단계, 이미지 1/2 Beats Studio3 Wireless Speaker Replacement, Ear Pad: 1 단계, 이미지 2/2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: 2 단계, 이미지 1/3 Beats Studio3 Wireless Speaker Replacement: 2 단계, 이미지 2/3 Beats Studio3 Wireless Speaker Replacement: 2 단계, 이미지 3/3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: 3 단계, 이미지 1/2 Beats Studio3 Wireless Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: 4 단계, 이미지 1/3 Beats Studio3 Wireless Speaker Replacement: 4 단계, 이미지 2/3 Beats Studio3 Wireless Speaker Replacement: 4 단계, 이미지 3/3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: 5 단계, 이미지 1/3 Beats Studio3 Wireless Speaker Replacement: 5 단계, 이미지 2/3 Beats Studio3 Wireless Speaker Replacement: 5 단계, 이미지 3/3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
결론
Nayeli watts
회원 가입일: 03/16/23
474 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 39
30일 전: 103
전체 시간: 918
