주요 콘텐츠로 건너뛰기
Beboncool Gamepad for Nintendo Switch Battery Replacement
필요한 것
  1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 1 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 1 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 1 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Battery Replacement: 2 단계, 이미지 2개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Battery Replacement: 3 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 3 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Battery Replacement: 4 단계, 이미지 2개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Battery Replacement: 5 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 5 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: 6 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: 6 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: 6 단계, 이미지 3개 중 3개
    • Carefully separate the battery which is adhered to the circuit board.
  7. Beboncool Gamepad for Nintendo Switch Battery Replacement: 7 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 7 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Battery Replacement: 7 단계, 이미지 3개 중 3개
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Riley McCullough
회원 가입일: 01/30/20
306 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 840
