주요 콘텐츠로 건너뛰기
Beboncool Gamepad for Nintendo Switch Joystick Replacement
필요한 것
  1. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 1 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 1 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 1 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 2 단계, 이미지 2개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 3 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 3 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 3 단계, 이미지 3개 중 3개
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 4 단계, 이미지 2개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 5 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 5 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Joystick: 6 단계, 이미지 2개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement, Joystick: 6 단계, 이미지 2개 중 2개
    • Remove the joystick cover from the joystick actuator by firmly pulling the cover away from the actuator.
  7. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 7 단계, 이미지 2개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 7 단계, 이미지 2개 중 2개
    • Gently separate the battery pack from the back of the motherboard, leaving it connected to the board through its lead cables.
  8. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 8 단계, 이미지 1개 중 1개
    • Bend each of the retaining tabs located in the the corners of each joystick actuator straight so that they can be removed.
    • If only one of your joysticks is showing issues, just address the pins corresponding to the problematic joystick.
  9. Beboncool Gamepad for Nintendo Switch Joystick Replacement: 9 단계, 이미지 3개 중 1개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 9 단계, 이미지 3개 중 2개 Beboncool Gamepad for Nintendo Switch Joystick Replacement: 9 단계, 이미지 3개 중 3개
    • Desolder the 12 soldering points connecting the problematic actuator(s) to the motherboard.
    • Remove the actuator from the board.
    • For help with soldering best practices, check out this Soldering and Desoldering Connections Guide.
결론
작성자
3다른 기여자 명과 함께
Patrick
회원 가입일: 01/30/20
402 평판
안내서 3개를 작성함
1가이드 댓글
Me who used my no longer existing nails for the grips lol
TheGuyInTheChair - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 26
전체 시간: 867
