소개
Instructions for removing the rear guard/cover to access internal components for service.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
