주요 콘텐츠로 건너뛰기
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement
필요한 것
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: 1 단계, 이미지 3개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: 1 단계, 이미지 3개 중 2개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: 1 단계, 이미지 3개 중 3개
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 2 단계, 이미지 2개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 3 단계, 이미지 2개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 4 단계, 이미지 3개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 4 단계, 이미지 3개 중 2개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 4 단계, 이미지 3개 중 3개
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 5 단계, 이미지 3개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 5 단계, 이미지 3개 중 2개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 5 단계, 이미지 3개 중 3개
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 6 단계, 이미지 2개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 6 단계, 이미지 2개 중 2개
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 7 단계, 이미지 2개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 7 단계, 이미지 2개 중 2개
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 8 단계, 이미지 3개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 8 단계, 이미지 3개 중 2개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 8 단계, 이미지 3개 중 3개
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 9 단계, 이미지 3개 중 1개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 9 단계, 이미지 3개 중 2개 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: 9 단계, 이미지 3개 중 3개
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
447,558 평판
안내서 259개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 2,364
