주요 콘텐츠로 건너뛰기
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
필요한 것
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: 1 단계, 이미지 1/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: 1 단계, 이미지 2/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: 1 단계, 이미지 3/3
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 2 단계, 이미지 1/2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 3 단계, 이미지 1/2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 3 단계, 이미지 2/2
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 4 단계, 이미지 1/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 4 단계, 이미지 2/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 4 단계, 이미지 3/3
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 5 단계, 이미지 1/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 5 단계, 이미지 2/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 5 단계, 이미지 3/3
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 6 단계, 이미지 1/2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 6 단계, 이미지 2/2
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 7 단계, 이미지 1/2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 7 단계, 이미지 2/2
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 8 단계, 이미지 1/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 8 단계, 이미지 2/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 8 단계, 이미지 3/3
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 9 단계, 이미지 1/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 9 단계, 이미지 2/3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 9 단계, 이미지 3/3
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: 10 단계, 이미지 1/2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: 10 단계, 이미지 2/2
    • Use a Phillips #2 driver to remove the two screws securing the throttle control.
    • While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 11 단계, 이미지 1/2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 11 단계, 이미지 2/2
    • Remove the throttle control.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
418,662 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Community
136 회원들
안내서 15,177개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 907
