주요 콘텐츠로 건너뛰기
Bissell Air180 Motherboard Replacement
필요한 것
  1. Bissell Air180 Motherboard Replacement, Air Filter: 1 단계, 이미지 2개 중 1개 Bissell Air180 Motherboard Replacement, Air Filter: 1 단계, 이미지 2개 중 2개
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Motherboard Replacement, Power Supply: 4 단계, 이미지 1개 중 1개
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Bissell Air180 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Bissell Air180 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Motherboard Replacement, Control Buttons: 6 단계, 이미지 3개 중 1개 Bissell Air180 Motherboard Replacement, Control Buttons: 6 단계, 이미지 3개 중 2개 Bissell Air180 Motherboard Replacement, Control Buttons: 6 단계, 이미지 3개 중 3개
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Bissell Air180 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Bissell Air180 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
  9. Bissell Air180 Motherboard Replacement, Fan: 9 단계, 이미지 3개 중 1개 Bissell Air180 Motherboard Replacement, Fan: 9 단계, 이미지 3개 중 2개 Bissell Air180 Motherboard Replacement, Fan: 9 단계, 이미지 3개 중 3개
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
  10. Bissell Air180 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Bissell Air180 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
  11. Bissell Air180 Motherboard Replacement, Motherboard: 11 단계, 이미지 2개 중 1개 Bissell Air180 Motherboard Replacement, Motherboard: 11 단계, 이미지 2개 중 2개
    • Apply pressure and push out the control knob to remove the motherboard from the rest of the device.
    • Removing the two 11mm Phillips #1 screws when disconnecting the fan also disconnected the motherboard from the rest of the device.
결론
작성자
2다른 기여자 명과 함께
Aleah Ramos
회원 가입일: 10/26/22
533 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-4, Botvin Fall 2022 UMass Dartmouth, Team 3-4, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G4
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 4
전체 시간: 121
