주요 콘텐츠로 건너뛰기
Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement
  1. Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement, Dust Tank and Dust Tank Filters: 1 단계, 이미지 1/2 Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement, Dust Tank and Dust Tank Filters: 1 단계, 이미지 2/2
    • Press the grey button while pulling the dirt tank up.
  2. Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement: 2 단계, 이미지 1/3 Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement: 2 단계, 이미지 2/3 Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement: 2 단계, 이미지 3/3
    • Twist the top green lid clockwise while holding the main dirt tank assembly still.
    • Once the top green lid can no longer be rotated, remove it from the rest of the dirt tank assembly.
    • Make sure to empty the tank first, or be prepared for a mess!
    • To just remove dust, the bottom button can be used to open the release.
  3. Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement: 3 단계, 이미지 1/1
    • Rotate the filter assembly clockwise.
    • Once the filter assembly can no longer be rotated clockwise, remove it from the top lid of the dirt tank.
  4. Bissell Zing 2156A Dust Tank and Dust Tank Filters Replacement: 4 단계, 이미지 1/1
    • Slide the filter screen from the filter to remove it.
    • The screen can be washed, while the filter can be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emma R
회원 가입일: 02/14/24
498 평판
안내서 3개 작성하였습니다
University of Memphis, Team 3-4, Sneed Spring 2024 University of Memphis, Team 3-4, Sneed Spring 2024 회원
UM-SNEED-S24S3G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 90
