주요 콘텐츠로 건너뛰기
Black and Decker LDX 120C Light Replacement
필요한 것
  1. Black and Decker LDX 120C Light  Replacement, Outer Case: 1 단계, 이미지 1/1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Light  Replacement: 2 단계, 이미지 1/1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Light  Replacement: 3 단계, 이미지 1/1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Light  Replacement: 4 단계, 이미지 1/1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Light  Replacement: 5 단계, 이미지 1/1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Light  Replacement: 6 단계, 이미지 1/1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Light  Replacement: 7 단계, 이미지 1/1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Light  Replacement, Light: 8 단계, 이미지 1/1
    • After following the prerequisite guide the drill is now open and you can see all the components of the drill.
  9. Black and Decker LDX 120C Light  Replacement: 9 단계, 이미지 1/1
    • First separate the top part of the drill, which includes the motor and the chuck, from the rest of the components.
    • Remove carefully so that wire connection is not damaged throughout this process.
  10. Black and Decker LDX 120C Light  Replacement: 10 단계, 이미지 1/1
    • Then separate the other component which includes the trigger, light, and the connection to the battery.
    • Do this carefully so that no wire connection or any component gets damaged.
  11. Black and Decker LDX 120C Light  Replacement: 11 단계, 이미지 1/1
    • First check if the connection to the light is not intact.
    • If the wiring is lose simply reconnect the wire.
    • Then check if the light bulb is not damaged in any way.
    • If the light bulb is broken or simply just burnt; simply replace the light bulb.
  12. Black and Decker LDX 120C Light  Replacement: 12 단계, 이미지 1/1
    • Grab the connection of the light bulb.
  13. Black and Decker LDX 120C Light  Replacement: 13 단계, 이미지 1/1
    • Using pliers cut the two connecting wires from the mother chip.
    • To prevent potential damage to the component, try desoldering the wires. Learn more about soldering here.
결론
jeffrey zakka
회원 가입일: 02/09/16
735 평판
안내서 6개 작성하였습니다
USF Tampa, Team 11-5, Cheng Spring 2016 USF Tampa, Team 11-5, Cheng Spring 2016 회원
USFT-CHENG-S16S11G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 46
전체 시간: 17,547
