주요 콘텐츠로 건너뛰기
Black and Decker LI2000 Circuit Board Replacement
필요한 것
  1. Black and Decker LI2000 Circuit Board Replacement, Orange Casing: 1 단계, 이미지 1/3 Black and Decker LI2000 Circuit Board Replacement, Orange Casing: 1 단계, 이미지 2/3 Black and Decker LI2000 Circuit Board Replacement, Orange Casing: 1 단계, 이미지 3/3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Circuit Board Replacement: 2 단계, 이미지 1/1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Circuit Board Replacement: 3 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Circuit Board Replacement: 4 단계, 이미지 1/1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Circuit Board Replacement, Handle: 5 단계, 이미지 1/2 Black and Decker LI2000 Circuit Board Replacement, Handle: 5 단계, 이미지 2/2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Circuit Board Replacement: 6 단계, 이미지 1/2 Black and Decker LI2000 Circuit Board Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Circuit Board Replacement, Battery: 7 단계, 이미지 1/2 Black and Decker LI2000 Circuit Board Replacement, Battery: 7 단계, 이미지 2/2
    • Using pliers or your fingers, remove the leads off of the battery.
  8. Black and Decker LI2000 Circuit Board Replacement, Circuit Board: 8 단계, 이미지 1/1
    • Refer to the Soldering Technique Guide to remove the wires on the circuit board that connect the charging adapter by applying heat from iron to existing solder on the board.
    • Keep track of which wire connected to which part of the board.
  9. Black and Decker LI2000 Circuit Board Replacement: 9 단계, 이미지 1/1
    • Refer to the Soldering Technique Guide to remove the wires from the circuit board that connect to the battery by heating the existing solder on the leads.
    • Keep track of which wire was connected to which part of the circuit board.
결론
Katherine Simmons
회원 가입일: 02/08/16
732 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-3, Baechle Spring 2016 IUPUI, Team 1-3, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 538
