주요 콘텐츠로 건너뛰기
Black and Decker Pivot MAX Power Switch Replacement
필요한 것
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: 1 단계, 이미지 1/2 Black and Decker Pivot MAX Power Switch Replacement, Battery: 1 단계, 이미지 2/2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: 2 단계, 이미지 1/1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: 3 단계, 이미지 1/1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: 4 단계, 이미지 1/1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: 5 단계, 이미지 1/1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: 6 단계, 이미지 1/1
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: 7 단계, 이미지 1/1
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: 8 단계, 이미지 1/3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: 8 단계, 이미지 2/3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: 8 단계, 이미지 3/3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: 9 단계, 이미지 1/2 Black and Decker Pivot MAX Power Switch Replacement: 9 단계, 이미지 2/2
결론
Avery Hanulcik
회원 가입일: 09/15/20
316 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 904
