주요 콘텐츠로 건너뛰기
Blink Video Doorbell Lens Replacement
필요한 것
  1. Blink Video Doorbell Lens Replacement, Battery: 1 단계, 이미지 3개 중 1개 Blink Video Doorbell Lens Replacement, Battery: 1 단계, 이미지 3개 중 2개 Blink Video Doorbell Lens Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Lens Replacement: 2 단계, 이미지 3개 중 1개 Blink Video Doorbell Lens Replacement: 2 단계, 이미지 3개 중 2개 Blink Video Doorbell Lens Replacement: 2 단계, 이미지 3개 중 3개
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Lens Replacement: 3 단계, 이미지 3개 중 1개 Blink Video Doorbell Lens Replacement: 3 단계, 이미지 3개 중 2개 Blink Video Doorbell Lens Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Lens Replacement, Back Panel: 4 단계, 이미지 3개 중 1개 Blink Video Doorbell Lens Replacement, Back Panel: 4 단계, 이미지 3개 중 2개 Blink Video Doorbell Lens Replacement, Back Panel: 4 단계, 이미지 3개 중 3개
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Lens Replacement, Lens: 5 단계, 이미지 3개 중 1개 Blink Video Doorbell Lens Replacement, Lens: 5 단계, 이미지 3개 중 2개 Blink Video Doorbell Lens Replacement, Lens: 5 단계, 이미지 3개 중 3개
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Lens Replacement: 6 단계, 이미지 2개 중 1개 Blink Video Doorbell Lens Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift up the small daughterboard which contains the camera.
    • Remove two 5 mm screws from the back of the camera using a Phillips #0 screwdriver.
  7. Blink Video Doorbell Lens Replacement: 7 단계, 이미지 2개 중 1개 Blink Video Doorbell Lens Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the lens.
결론
작성자
4다른 기여자 명과 함께
Kayla Crai
회원 가입일: 10/18/24
495 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-1, Konn Fall 2024 UMass Dartmouth, Team 1-1, Konn Fall 2024 회원
UMASSD-KONN-F24S1G1
4 회원들
안내서 5개를 작성함
댓글 한 개
Is it available to purchase the lens
William - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 120
전체 시간: 395
