주요 콘텐츠로 건너뛰기
Blu Grand M Display Replacement
필요한 것
  1. Blu Grand M Display Replacement, Display: 1 단계, 이미지 1/1
    • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
    • Melting the adhesive can take between 2-3 minutes.
  2. Blu Grand M Display Replacement: 2 단계, 이미지 1/3 Blu Grand M Display Replacement: 2 단계, 이미지 2/3 Blu Grand M Display Replacement: 2 단계, 이미지 3/3
    • Insert an opening pick between the screen and the raised black plastic frame.
    • The black plastic frame is located inside and above the phone's silvery outer metal frame.
    • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
    • Pull the spudger blade through the adhesive around the circumference of the screen.
  3. Blu Grand M Display Replacement: 3 단계, 이미지 1/3 Blu Grand M Display Replacement: 3 단계, 이미지 2/3 Blu Grand M Display Replacement: 3 단계, 이미지 3/3
    • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
    • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
    • Pull on the handle to lift the screen free from the device.
결승점
Liam Rollins
회원 가입일: 11/04/19
253 평판
안내서 2개 작성하였습니다
Idaho State University, Team S1-G2, Watkins Fall 2019 Idaho State University, Team S1-G2, Watkins Fall 2019 회원
ISU-WATKINS-F19S1G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 239
