주요 콘텐츠로 건너뛰기
Blu Grand M2 Charging Port Assembly Replacement
필요한 것
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: 2 단계, 이미지 2개 중 1개 Blu Grand M2 Charging Port Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Richard Hills
회원 가입일: 09/10/18
150 평판
안내서 1개를 작성함
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 회원
GCC-LUSTER-F18S1G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 618
