소개
This guide will be helpful if your camera has become cloudy and in need of cleaning, or even if it needs to be replaced outright.
필요한 것
1 단계 Battery
주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Flip over your Studio 5.5 so the back is facing you.
Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
Begin by removing the 12 3.5mm screws along the back of the device.
1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
다른 3명이 해당 안내서를 완성하였습니다.
