소개
In this guide, we will be removing the micro usb port and the circuit board it is attached to, so that a new one may be installed.
필요한 것
1 단계 Battery
주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Flip over your Studio 5.5 so the back is facing you.
Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
Begin by removing the 12 screws along the back of the device.
1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 3개
i want buy chargin port sir my blue cahrging port was dead plz help me i want buy
Where do i buy the %#*@ micro usb port
