주요 콘텐츠로 건너뛰기
Blu Studio 5.5 Touchscreen Display Replacement
필요한 것
  1. Blu Studio 5.5 Touchscreen Display Replacement, Battery: 1 단계, 이미지 1/3 Blu Studio 5.5 Touchscreen Display Replacement, Battery: 1 단계, 이미지 2/3 Blu Studio 5.5 Touchscreen Display Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Touchscreen Display Replacement: 2 단계, 이미지 1/2 Blu Studio 5.5 Touchscreen Display Replacement: 2 단계, 이미지 2/2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Touchscreen Display Replacement: 3 단계, 이미지 1/3 Blu Studio 5.5 Touchscreen Display Replacement: 3 단계, 이미지 2/3 Blu Studio 5.5 Touchscreen Display Replacement: 3 단계, 이미지 3/3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Touchscreen Display Replacement, Back Panel Assembly: 4 단계, 이미지 1/2 Blu Studio 5.5 Touchscreen Display Replacement, Back Panel Assembly: 4 단계, 이미지 2/2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Touchscreen Display Replacement: 5 단계, 이미지 1/3 Blu Studio 5.5 Touchscreen Display Replacement: 5 단계, 이미지 2/3 Blu Studio 5.5 Touchscreen Display Replacement: 5 단계, 이미지 3/3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Touchscreen Display Replacement, Touchscreen Display: 6 단계, 이미지 1/2 Blu Studio 5.5 Touchscreen Display Replacement, Touchscreen Display: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Locate the flex cable connector that connects the screen to the motherboard.
    • Using tweezers, gently remove the flex cable connector from the motherboard.
  7. Blu Studio 5.5 Touchscreen Display Replacement: 7 단계, 이미지 1/3 Blu Studio 5.5 Touchscreen Display Replacement: 7 단계, 이미지 2/3 Blu Studio 5.5 Touchscreen Display Replacement: 7 단계, 이미지 3/3
    • Using the spudger, begin to gently remove the adhesive around the screen.
    • Once all the border adhesive is removed, insert the pick between the screen and phone, Leave the spudger in to create space between the phone and screen to insert the pick.
    • If removing the adhesive is a challenge, you can use the iOpener by following the instructions to heat it up and placing it on the edges of the phone to loosen the adhesive.
  8. Blu Studio 5.5 Touchscreen Display Replacement: 8 단계, 이미지 1/3 Blu Studio 5.5 Touchscreen Display Replacement: 8 단계, 이미지 2/3 Blu Studio 5.5 Touchscreen Display Replacement: 8 단계, 이미지 3/3
    • Once the pic is inserted, slide it under and around the screen to remove any adhesive that may have been left under the screen.
    • Once the majority of the adhesive is removed, gently lift the screen using the opening tool or the spudger.
  9. Blu Studio 5.5 Touchscreen Display Replacement: 9 단계, 이미지 1/3 Blu Studio 5.5 Touchscreen Display Replacement: 9 단계, 이미지 2/3 Blu Studio 5.5 Touchscreen Display Replacement: 9 단계, 이미지 3/3
    • Once there is enough space between the phone and screen, feel free to use your hands to gently remove the screen completely.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alec Coleman
회원 가입일: 02/28/17
313 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G6, Nance Spring 2017 USF Tampa, Team S1-G6, Nance Spring 2017 회원
USFT-NANCE-S17S1G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 2,433
