주요 콘텐츠로 건너뛰기
How to Replace Blu Studio Selfie Microphone
필요한 것
  1. How to Replace Blu Studio Selfie Microphone, Rear Cover: 1 단계, 이미지 1/1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. How to Replace Blu Studio Selfie Microphone: 2 단계, 이미지 1/1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. How to Replace Blu Studio Selfie Microphone, Battery: 3 단계, 이미지 1/2 How to Replace Blu Studio Selfie Microphone, Battery: 3 단계, 이미지 2/2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. How to Replace Blu Studio Selfie Microphone, Midframe: 4 단계, 이미지 1/1
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. How to Replace Blu Studio Selfie Microphone: 5 단계, 이미지 1/1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. How to Replace Blu Studio Selfie Microphone: 6 단계, 이미지 1/1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
  7. How to Replace Blu Studio Selfie Microphone, Microphone: 7 단계, 이미지 1/2 How to Replace Blu Studio Selfie Microphone, Microphone: 7 단계, 이미지 2/2
    • Remove three 4 mm Phillips #000 screws holding the motherboard in place.
    • Carefully lift the motherboard from the phone, exposing the microphone soldering connections.
  8. How to Replace Blu Studio Selfie Microphone: 8 단계, 이미지 1/2 How to Replace Blu Studio Selfie Microphone: 8 단계, 이미지 2/2
    • Use a soldering iron to desolder the microphone from the phone.
    • Learn more about soldering here.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stacy Kam
회원 가입일: 01/20/16
630 평판
안내서 5개 작성하였습니다
USF Tampa, Team 10-1, Remmell Spring 2016 USF Tampa, Team 10-1, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 425
