주요 콘텐츠로 건너뛰기
Bose SoundDock Portable v2 Docking System Board Replacement
필요한 것
  1. Bose SoundDock Portable v2 Docking System Board Replacement, Docking System Board: 1 단계, 이미지 1개 중 1개
    • Lay the speaker flat on its back, balancing on the battery.
    • Remove the four rubber disks that cover the screws on the bottom of the speaker.
    • Follow the battery replacement guide to remove the battery
  2. Bose SoundDock Portable v2 Docking System Board Replacement: 2 단계, 이미지 1개 중 1개
    • Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
    • It may be easier to the remove the battery so that the speaker will lay flat on the table.
  3. Bose SoundDock Portable v2 Docking System Board Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the bottom panel of the speaker.
    • You may have to rock the panel back and forth to get it to slide off the plastic pegs.
  4. Bose SoundDock Portable v2 Docking System Board Replacement: 4 단계, 이미지 1개 중 1개
    • Once the panel is removed you will see a ribbon connecting the dock to the speaker. Be careful to orient the speaker so that you can work on the dock connector without pulling on the ribbon!
  5. Bose SoundDock Portable v2 Docking System Board Replacement: 5 단계, 이미지 2개 중 1개 Bose SoundDock Portable v2 Docking System Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
    • There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
  6. Bose SoundDock Portable v2 Docking System Board Replacement: 6 단계, 이미지 2개 중 1개 Bose SoundDock Portable v2 Docking System Board Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
    • There are some small parts that may fall out when the plastic pieces are separated. To minimize this, lay the piece with the dock connector facing down.
  7. Bose SoundDock Portable v2 Docking System Board Replacement: 7 단계, 이미지 2개 중 1개 Bose SoundDock Portable v2 Docking System Board Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Once the pieces are separated, the dock connector can be lifted out of the slot.
    • Using tweezers or your fingers, unplug the two ribbon connectors from the board.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Evan Low
회원 가입일: 04/14/15
584 평판
안내서 4개를 작성함
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 회원
CPSU-MANESS-S15S4G1
4 회원들
안내서 5개를 작성함
1가이드 댓글
How can I tell if it is my IPOD or the Bose system that needs to be repaired?
Ron Adams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 67
전체 시간: 22,386
