주요 콘텐츠로 건너뛰기
Bose SoundLink III Treble Speakers Replacement
필요한 것
  1. Bose SoundLink III Treble Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose SoundLink III Treble Speakers Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundLink III Treble Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
    easy peasy. great instructions!
    couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
    thank you ifixit for another great tutorial.
    scott
    Scott Oakley - 답글
    My SL III battery lasted nearly 8 years with almost daily use—but recently stopped holding a charge for more than 15-20 minutes. Replacement was super easy so thanks for posting. Bose quality is exceptional as always!
    hoya - 답글
  3. Bose SoundLink III Treble Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose SoundLink III Treble Speakers Replacement: 4 단계, 이미지 2개 중 1개 Bose SoundLink III Treble Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
    Super Erklärt!!
    Ralf s - 답글
    You do not have to remove the rubber completely. Just lift up the ends towards the middle to reveal the screws.
    bart - 답글
  5. Bose SoundLink III Treble Speakers Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Gently peel back the adhesive padding on either side of the inner back panel.
    • The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
  6. Bose SoundLink III Treble Speakers Replacement: 6 단계, 이미지 2개 중 1개 Bose SoundLink III Treble Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
    • Slide off the outer case.
  7. Bose SoundLink III Treble Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
    • All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
  8. Bose SoundLink III Treble Speakers Replacement: 8 단계, 이미지 2개 중 1개 Bose SoundLink III Treble Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
    • Now you should be able to lift the top panel off.
  9. Bose SoundLink III Treble Speakers Replacement: 9 단계, 이미지 2개 중 1개 Bose SoundLink III Treble Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
    • The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
  10. Bose SoundLink III Treble Speakers Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
  11. Bose SoundLink III Treble Speakers Replacement: 11 단계, 이미지 1개 중 1개
    • Gently disconnect the three cables connected to the motherboard.
    • Remove the motherboard from the device.
  12. Bose SoundLink III Treble Speakers Replacement, Speakers: 12 단계, 이미지 2개 중 1개 Bose SoundLink III Treble Speakers Replacement, Speakers: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • For each of the 4 treble speakers you must uncoil the red wire and black wire in order to remove them.
    • You may need metal tweezers in order to re-coil the replacement speaker.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dakoda Sanders
회원 가입일: 02/04/16
1,558 평판
안내서 4개를 작성함
USF Tampa, Team 3-2, Wollert Spring 2016 USF Tampa, Team 3-2, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G2
4 회원들
안내서 8개를 작성함
댓글 한 개
Hi,
Where can i buy the replacement speakers?
Scott - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 43
전체 시간: 4,981
