주요 콘텐츠로 건너뛰기
Braun Trimmer Battery Replacement and Modification
필요한 것
  1. Braun Trimmer Battery Replacement and Modification, Disassemble the trimmer: 1 단계, 이미지 1개 중 1개
    • First you need to disassemble the trimmer.
    • To access the four screws you would need first to open the frontal cover. Use opening picks, starting from the bottom of the trimmer
    • For detailed disassembly refer to another article on iFixit
  2. Braun Trimmer Battery Replacement and Modification, Print a holder for the batteries: 2 단계, 이미지 3개 중 1개 Braun Trimmer Battery Replacement and Modification, Print a holder for the batteries: 2 단계, 이미지 3개 중 2개 Braun Trimmer Battery Replacement and Modification, Print a holder for the batteries: 2 단계, 이미지 3개 중 3개
    • Print a holder for your new batteries on a 3D printer
    • I used a modified 3D model from ThingVerse
    • The original model is too big for the trimmer case. I modified the scale like following: X 97%, Y 84%; Z 95%
    • I stopped the printing at 60% of completion to keep the holder low enough to fit the trimmer case
  3. Braun Trimmer Battery Replacement and Modification, Remove the old batteries: 3 단계, 이미지 1개 중 1개
    • Remove the original dead batteries
    • I didn't have a soldering iron, so I used a heated knife to slowly detach the batteries from the connectors. It worked okay
  4. Braun Trimmer Battery Replacement and Modification, Attach the printed batteries holder: 4 단계, 이미지 2개 중 1개 Braun Trimmer Battery Replacement and Modification, Attach the printed batteries holder: 4 단계, 이미지 2개 중 2개
    • Place the 3D-printed battery case on the board so the connectors would go inside the case as you see on the pictures
  5. Braun Trimmer Battery Replacement and Modification, Place the new batteries: 5 단계, 이미지 3개 중 1개 Braun Trimmer Battery Replacement and Modification, Place the new batteries: 5 단계, 이미지 3개 중 2개 Braun Trimmer Battery Replacement and Modification, Place the new batteries: 5 단계, 이미지 3개 중 3개
    • Place the new batteries into the case. Pay attention to polarities
    • Before full assembly, you can test if the new batteries are charging
  6. Braun Trimmer Battery Replacement and Modification, Test: 6 단계, 이미지 2개 중 1개 Braun Trimmer Battery Replacement and Modification, Test: 6 단계, 이미지 2개 중 2개
    • After the battery has fully charged the trimmer should work as new
  7. Braun Trimmer Battery Replacement and Modification, Assemble: 7 단계, 이미지 3개 중 1개 Braun Trimmer Battery Replacement and Modification, Assemble: 7 단계, 이미지 3개 중 2개 Braun Trimmer Battery Replacement and Modification, Assemble: 7 단계, 이미지 3개 중 3개
    • Now you should be ready to assemble the trimmer back
  8. Braun Trimmer Battery Replacement and Modification, Profit: 8 단계, 이미지 2개 중 1개 Braun Trimmer Battery Replacement and Modification, Profit: 8 단계, 이미지 2개 중 2개
    • Enjoy the proper working time of your refreshed trimmer
결론
My old batteries barely lasted one minute of shaving, and never held any charge. I didn't test the full working time of the new batteries, but they allowed me to use the trimmer at least for 10 minutes.
Thanks to adding the battery holder next battery replacement would be way easier and faster.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
elwiwian
회원 가입일: 01/01/23
463 평판
안내서 1개를 작성함
1가이드 댓글
Would you provide the specs of the original batteries (mAh and Voltage)? So one can order spare parts in advance.
Tobias - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 97
지난 30일: 503
전체 시간: 10,888
