소개
Use this guide to remove the front speaker panel in your device. You’ll need to know how to solder to fully replace the speaker panel in your Braven BRV-X. The How to Solder and Desolder Connections guide may help you with this guide.
필요한 것
Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
거의 끝나갑니다!
결론
