소개
If the BrightSign player isn't working, it could be a power issue. This replacement guide will walk you through the process needed to replace the 12V 5A battery charging port on the device.
Tech Tip: this Replacement guide will require the use of a soldering iron to remove solders, so check out the soldering guide if you're unfamiliar with the process.
필요한 것
Remove three 8mm screws from the left side of the device.
Remove four 8mm screws from the right side of the device.
Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
Flip the motherboard over so the heatsink is facing down.
Desolder the four solder joints and remove the melted solder with the pump.
Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
Using the tweezers apply pressure to the spade head clip shown.
Remove the charging port by pulling the piece off.
