주요 콘텐츠로 건너뛰기
CASIO fx-300ES Plus Scientific Calculator Battery Replacement
필요한 것
  1. CASIO fx-300ES Plus Scientific Calculator Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the calculator by pressing the [Shift] button.
    • Press the [AC][OFF] button.
  2. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the calculator over so that the back panel faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • If the screw is not unfastening, do not force it because it can strip the screw. If the screw is already stripped see the 마모된 나사 분리 방법 guide.
  3. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery cover.
  4. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to pry out the battery.
    • Be gentle when removing the battery to avoid damaging it.
  5. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 5 단계, 이미지 2개 중 1개 CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Place the new LR44 alkaline battery into the calculator.
    • Be sure that the + sign is at the bottom.
  6. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Reattach the battery cover.
    • Insert the screw for the battery cover using a Phillips #0 screwdriver.
  7. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
결론
You have now successfully replaced a Casio FX-300ES battery.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Maha
회원 가입일: 07/08/20
285 평판
안내서 1개를 작성함
York University, Team S1-G22, Allen Summer 2020 York University, Team S1-G22, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G22
1 회원
안내서 5개를 작성함
1가이드 댓글
Below is a detailed video showing the battery replacement process.
https://youtu.be/I7pR-_Ra5W8
Tomatoman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 88
지난 30일: 378
전체 시간: 37,916
