주요 콘텐츠로 건너뛰기
CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
필요한 것
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: 1 단계, 이미지 1/1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 2 단계, 이미지 1/1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 3 단계, 이미지 1/2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 3 단계, 이미지 2/2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 4 단계, 이미지 1/2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 4 단계, 이미지 2/2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 5 단계, 이미지 1/3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 5 단계, 이미지 2/3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 5 단계, 이미지 3/3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: 6 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
결론
Annalise White
회원 가입일: 10/26/22
530 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G7
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 27
전체 시간: 255
