주요 콘텐츠로 건너뛰기
Canon EOS 30 Battery Door Replacement
필요한 것
  1. Canon EOS 30 Battery Door Replacement, Front Panel: 1 단계, 이미지 1/1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Battery Door Replacement: 2 단계, 이미지 1/1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Battery Door Replacement: 3 단계, 이미지 1/1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Battery Door Replacement: 4 단계, 이미지 1/1
    • Remove the front panel by lifting it away from the camera's body.
    I need a video tutorial
    Abdullah dicky S - 답글
  5. Canon EOS 30 Battery Door Replacement, Bottom Panel: 5 단계, 이미지 1/1
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Canon EOS 30 Battery Door Replacement: 6 단계, 이미지 1/1
    • Remove the bottom panel.
  7. Canon EOS 30 Battery Door Replacement, Side Panel With Remote Control Socket: 7 단계, 이미지 1/1
    • Remove two 6.5 mm black screws from the panel.
  8. Canon EOS 30 Battery Door Replacement: 8 단계, 이미지 1/1
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Canon EOS 30 Battery Door Replacement: 9 단계, 이미지 1/2 Canon EOS 30 Battery Door Replacement: 9 단계, 이미지 2/2
    • Slide the panel toward the bottom of the camera to remove.
  10. Canon EOS 30 Battery Door Replacement: 10 단계, 이미지 1/1
    • Remove the single 4.8 silver screw from the control socket.
  11. Canon EOS 30 Battery Door Replacement: 11 단계, 이미지 1/2 Canon EOS 30 Battery Door Replacement: 11 단계, 이미지 2/2
    • The control socket is now secure by three wires.
    • Desolder connections to replace the remote control socket.
  12. Canon EOS 30 Battery Door Replacement, Top Panel: 12 단계, 이미지 1/1
    • Slide the outer eyepiece upward to remove it.
  13. Canon EOS 30 Battery Door Replacement: 13 단계, 이미지 1/1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  14. Canon EOS 30 Battery Door Replacement: 14 단계, 이미지 1/1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  15. Canon EOS 30 Battery Door Replacement: 15 단계, 이미지 1/2 Canon EOS 30 Battery Door Replacement: 15 단계, 이미지 2/2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  16. Canon EOS 30 Battery Door Replacement, Grip: 16 단계, 이미지 1/1
    • Remove the two 5.5 mm screws from front of camera.
  17. Canon EOS 30 Battery Door Replacement: 17 단계, 이미지 1/1
    • Remove grip panel.
  18. Canon EOS 30 Battery Door Replacement, Battery Door: 18 단계, 이미지 1/1
    • Remove one black screw from battery door on underside of grip.
  19. Canon EOS 30 Battery Door Replacement: 19 단계, 이미지 1/1
    • Remove battery door.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jackie
회원 가입일: 04/17/11
236 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 22개 작성하였습니다
댓글 한 개
I was able to complete this by going from step 9 to 15. Oddly, I only had one screw to remove in step 15 but the grip piece easily slid out without needing to remove the top of the camera.
Alan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 17
전체 시간: 4,103
