주요 콘텐츠로 건너뛰기
Canon EOS 40D Date and Time Battery Replacement
필요한 것
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 4 단계, 이미지 3개 중 1개 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 4 단계, 이미지 3개 중 2개 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 4 단계, 이미지 3개 중 3개
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the date and time battery from the battery holder.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Doug Kruse
회원 가입일: 09/03/15
788 평판
안내서 3개를 작성함
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G3
4 회원들
안내서 16개를 작성함
6가이드 댓글
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - 답글
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - 답글
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - 답글
Great help! Accurate, easy to follow directions
Jack Applegate - 답글
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 27
지난 30일: 135
전체 시간: 16,913
