주요 콘텐츠로 건너뛰기
Canon EOS Rebel T2i Front Cover Replacement
필요한 것
  1. Canon EOS Rebel T2i Front Cover Replacement, I/F Terminal Cover: 1 단계, 이미지 3개 중 1개 Canon EOS Rebel T2i Front Cover Replacement, I/F Terminal Cover: 1 단계, 이미지 3개 중 2개 Canon EOS Rebel T2i Front Cover Replacement, I/F Terminal Cover: 1 단계, 이미지 3개 중 3개
    • Before beginning, ensure that the camera is off, and the battery is removed.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T2i Front Cover Replacement, Remove the back casing.: 2 단계, 이미지 2개 중 1개 Canon EOS Rebel T2i Front Cover Replacement, Remove the back casing.: 2 단계, 이미지 2개 중 2개
    • On the left side of the camera, remove the following screw:
    • One M1.7x6.0mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon EOS Rebel T2i Front Cover Replacement: 3 단계, 이미지 2개 중 1개 Canon EOS Rebel T2i Front Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x2.5mm JIS #000 screws
  4. Canon EOS Rebel T2i Front Cover Replacement, Open the back panel.: 4 단계, 이미지 3개 중 1개 Canon EOS Rebel T2i Front Cover Replacement, Open the back panel.: 4 단계, 이미지 3개 중 2개 Canon EOS Rebel T2i Front Cover Replacement, Open the back panel.: 4 단계, 이미지 3개 중 3개
    • Slide the viewfinder eyepiece vertically upwards.
    • Start to pull the back cover partially off of the camera.
    • Use caution when removing the back cover, there is a ribbon cable that connects the LCD screen to the main PCB board.
    • Disconnect the LCD screen ribbon cable from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
    • Finish pulling the back cover off of the camera body.
  5. Canon EOS Rebel T2i Front Cover Replacement, Front Cover: 5 단계, 이미지 2개 중 1개 Canon EOS Rebel T2i Front Cover Replacement, Front Cover: 5 단계, 이미지 2개 중 2개
    • Remove the following screws from the front of the camera:
    • Two M1.7x5.5mm JIS #000 screws
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T2i Front Cover Replacement: 6 단계, 이미지 3개 중 1개 Canon EOS Rebel T2i Front Cover Replacement: 6 단계, 이미지 3개 중 2개 Canon EOS Rebel T2i Front Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
결론
첨부 문서
작성자
1다른 기여자 명과 함께
Zephosk
회원 가입일: 09/26/24
4,557 평판
안내서 27개를 작성함
LGBTQ Technicians LGBTQ Technicians 회원
Community
33 회원들
안내서 96개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 5
전체 시간: 19
