주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon Pixma MP480 Data Port Replacement
필요한 것
    1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: 1 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: 1 단계, 이미지 2개 중 2개
      • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Canon Pixma MP480 Data Port Replacement: 2 단계, 이미지 1개 중 1개
      • Lift up the back cover to remove it.
      • You may need to lift firmly as it requires quite a bit of force.
      댓글 쓰기
    3. Canon Pixma MP480 Data Port Replacement: 3 단계, 이미지 1개 중 1개
      • Open the front tray.
      댓글 쓰기
    4. Canon Pixma MP480 Data Port Replacement: 4 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 4 단계, 이미지 2개 중 2개
      • Open the scanner compartment.
      • Make sure the blue lever locks into place to keep the compartment open.
      댓글 쓰기
    5. Canon Pixma MP480 Data Port Replacement: 5 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the blue lever from its slot by pushing it back and twisting clockwise.
      • Close the scanner compartment and cover.
      댓글 쓰기
    6. Canon Pixma MP480 Data Port Replacement: 6 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 6 단계, 이미지 2개 중 2개
      • Pry open the side cover with the plastic opening tool.
      댓글 쓰기
    7. Canon Pixma MP480 Data Port Replacement: 7 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 7 단계, 이미지 2개 중 2개
      • Flip the printer over so that the bottom of the printer is facing you.
      • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
      댓글 쓰기
    8. Canon Pixma MP480 Data Port Replacement: 8 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 8 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
      댓글 쓰기
    1. Canon Pixma MP480 Data Port Replacement, LCD: 9 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement, LCD: 9 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, pry off the top cover of the LCD assembly.
      • Pry around the front and side edges for the easiest removal.
      댓글 쓰기
    2. Canon Pixma MP480 Data Port Replacement: 10 단계, 이미지 1개 중 1개
      • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
      댓글 쓰기
    3. Canon Pixma MP480 Data Port Replacement: 11 단계, 이미지 1개 중 1개
      • Gently pull the ribbon cable to remove the LCD completely.
      댓글 쓰기
    1. Canon Pixma MP480 Data Port Replacement, Buttons: 12 단계, 이미지 1개 중 1개
      • Locate the buttons on the top of the printer.
      댓글 쓰기
    2. Canon Pixma MP480 Data Port Replacement: 13 단계, 이미지 1개 중 1개
      • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
      댓글 쓰기
    3. Canon Pixma MP480 Data Port Replacement: 14 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
      댓글 쓰기
    4. Canon Pixma MP480 Data Port Replacement: 15 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 15 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
      댓글 쓰기
    5. Canon Pixma MP480 Data Port Replacement: 16 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
      댓글 쓰기
    6. Canon Pixma MP480 Data Port Replacement: 17 단계, 이미지 1개 중 1개
      • Gently pull the LCD screen up to remove it from its fixture.
      댓글 쓰기
    7. Canon Pixma MP480 Data Port Replacement: 18 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to pry off the plastic button assembly.
      댓글 쓰기
    8. Canon Pixma MP480 Data Port Replacement: 19 단계, 이미지 1개 중 1개
      • Gently pull the plastic button assembly up to remove it.
      • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
      댓글 쓰기
    9. Canon Pixma MP480 Data Port Replacement: 20 단계, 이미지 1개 중 1개
      • Remove the ribbon cable connected to the backside of the plastic button assembly.
      댓글 쓰기
    10. Canon Pixma MP480 Data Port Replacement: 21 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 21 단계, 이미지 2개 중 2개
      • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
      댓글 쓰기
    11. Canon Pixma MP480 Data Port Replacement: 22 단계, 이미지 3개 중 1개 Canon Pixma MP480 Data Port Replacement: 22 단계, 이미지 3개 중 2개 Canon Pixma MP480 Data Port Replacement: 22 단계, 이미지 3개 중 3개
      • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
      • Gently lift the spring and pull the board out of its plastic button assembly.
      댓글 쓰기
    12. Canon Pixma MP480 Data Port Replacement: 23 단계, 이미지 1개 중 1개
      • Remove the buttons from the plastic button assembly.
      댓글 쓰기
    1. Canon Pixma MP480 Data Port Replacement, Data Port: 24 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement, Data Port: 24 단계, 이미지 2개 중 2개
      • Remove the 7.5 mm screw using the Phillips #1 screwdriver.
      댓글 쓰기
    2. Canon Pixma MP480 Data Port Replacement: 25 단계, 이미지 2개 중 1개 Canon Pixma MP480 Data Port Replacement: 25 단계, 이미지 2개 중 2개
      • Remove the five 3.5 mm screws using the Phillips #1 screwdriver.
      댓글 쓰기
    3. Canon Pixma MP480 Data Port Replacement: 26 단계, 이미지 1개 중 1개
      • Remove the small plastic clip using the spudger.
      댓글 쓰기
    4. Canon Pixma MP480 Data Port Replacement: 27 단계, 이미지 1개 중 1개
      • Pull the plastic inserts out of the holes in the top and bottom.
      댓글 쓰기
    5. Canon Pixma MP480 Data Port Replacement: 28 단계, 이미지 1개 중 1개
      • Remove the board from the printer by pulling the board towards the back of the printer.
      • This requires effort and time as the board comes out slowly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Steven MacLean
회원 가입일: 01/14/13
86 평판
안내서 2개를 작성함
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013 회원
CPSU-REGAN-W13S19G41
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 42
전체 시간: 2,750
