주요 콘텐츠로 건너뛰기
Canon PowerShot A4000 IS Flash Replacement
필요한 것
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: 1 단계, 이미지 1/3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: 1 단계, 이미지 2/3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: 1 단계, 이미지 3/3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: 2 단계, 이미지 1/2 Canon PowerShot A4000 IS Flash Replacement: 2 단계, 이미지 2/2
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: 3 단계, 이미지 1/3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: 3 단계, 이미지 2/3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: 3 단계, 이미지 3/3
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
결론
Ansley Gardner
회원 가입일: 10/13/14
761 평판
안내서 7개 작성하였습니다
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 회원
CLEM-BENSON-F14S1G3
3 회원들
안내서 17개 작성하였습니다
댓글 한 개
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 20
전체 시간: 1,553
