주요 콘텐츠로 건너뛰기
Canon PowerShot A4000 IS Front Cover Replacement
필요한 것
  1. Canon PowerShot A4000 IS Front Cover Replacement, Removing the Screws Anchoring the Front Cover: 1 단계, 이미지 1/3 Canon PowerShot A4000 IS Front Cover Replacement, Removing the Screws Anchoring the Front Cover: 1 단계, 이미지 2/3 Canon PowerShot A4000 IS Front Cover Replacement, Removing the Screws Anchoring the Front Cover: 1 단계, 이미지 3/3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Front Cover Replacement: 2 단계, 이미지 1/2 Canon PowerShot A4000 IS Front Cover Replacement: 2 단계, 이미지 2/2
    • Use the spudger tool to gently lever the front cover off.
결론
Ashley Heslip
회원 가입일: 10/13/14
309 평판
안내서 3개 작성하였습니다
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 회원
CLEM-BENSON-F14S1G3
3 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 15
전체 시간: 944
