이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
First you will remove the batteries and back cover of the camera. You will unscrew the LCD. You will then remove the ribbon attached to the logic board. Finally you will unsolder the LCD from the logic board.
필요한 것
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
With the LCD pulled back in one hand and using a blue iPod opener tool, pull the black retaining clip up and remove the ribbon.
Use tweezers to unsolder the wires from the bottom left corner on the back of the LCD.
Remove the solder from the wires.
다른 한 분이 해당 안내서를 완성하였습니다.
